Firecapt1's avatar
Firecapt1
Can't seem to hide/disable SSID broadcast
Just got my router today, it's all set up and working well except I can't seem to disable the SSID broadcast for the WiFi.  I know that the box that says "Enable SSID Broadcast " should be unchecked,...
  • Firecapt's avatar
    Firecapt
    May 29, 2018
    I did a factory reset on the router and that seems to have solved the problem.  Thanks to everyone for the help! :smileyvery-happy:
