Firecapt1
Apr 05, 2018Aspirant
Can't seem to hide/disable SSID broadcast
Just got my router today, it's all set up and working well except I can't seem to disable the SSID broadcast for the WiFi. I know that the box that says "Enable SSID Broadcast " should be unchecked,...
- May 29, 2018
I did a factory reset on the router and that seems to have solved the problem. Thanks to everyone for the help! :smileyvery-happy:
JamesGL
May 04, 2018NETGEAR Employee Retired
Hi Firecapt1,
Have you tried to reset the router to factory default?
JamesGL
May 28, 2018NETGEAR Employee Retired
Hi Firecapt1,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- FirecaptMay 29, 2018Aspirant
