pistos's avatar
pistos
Follower
Jul 25, 2017
Can't select folder in ReadyCloud App
I've attached a Seagate 8T drive to my R8000 router and turned on ReadyCloud. On a remote computer, running Windows 10, I downloaded the ReadCloud Desktop client and signed in. I can see my router an...
  • JamesGL's avatar
    Aug 03, 2017
    Hi pistos,
    If you have antivirus, try to exempt the ReadyCloud App.
    Try to install it as well to a different computer.
