JimCrowley
Aug 15, 2022Follower
can't 'select' router, nor get on paid Spectrum link to disney etc. Nighthawk X10 AD7200 (R9000)
Re: Nighthawk X10 AD7200 Smart Wi Fi Router (R9000) Tried to add (10-yr-old/smart) Samsung TV # 2 on network. Did something wrong. Older TV asked me to specify a security type. But front of route...
Aug 15, 2022Guru - Experienced User
How is the wifi configured on the Router?
Is smart connect enabled on the router?
What security mode are you using? WPA2 and AES is recommended/
Try changing the wifi SSID name to something different along with creating a new password?
- TC_in_MontanaAug 15, 2022Virtuoso
I see you mentioned you pushed some buttons on the front of the router.
Is the button on the far right (as you are looking at it) lighted? This button turns on and turns off the WiFi signal.
If it is NOT lighted, press it and hold it for 2 - 3 seconds and see if it stays lighted.
Then go back and check the ability to see the router at your television.
