Jonus9512131's avatar
Jonus9512131
Initiate
Mar 14, 2020
Can't set up used Nighthawk R7000
Hi,
One of my friends gave me his used Nighthawk R7000, as he had upgraded to something else in the summer as we were having trouble with WiFi range in our old house.  Trouble is I can't set it up as Netgear says it is already registered to Andrew and I can't contact Netgear because the router is out of' 'complimentary help' period being over one year old - pretty useless service and would be really annoyed if I had paid for the router.  Is there anyway to get the router going or is it just a paperweight?
Any advice gratefully received!
Thanks,
Jon
  • Jon.
    No need and zero benefit of registering your router. Use the reset button on the back. Connect a PC to one of its LAN ports and open an internet browser. Navigate to 192.168.1.1.
    Log in using admin as the username and password as the password. Now set up the router as your own.
  • Jon.
    • Jonus9512131's avatar
      Jonus9512131
      Initiate
      Thanks so much for the clear advice.  I am not great with these things so really grateful for the help!
      Best wishes,
      Jon
