jaret1963's avatar
jaret1963
Follower
Jan 05, 2022
cant sign into my new netgear
can't log into my brand new out the box NetGear R6080 , try using admin/password ..password would not let me in. using routerlogin.com /net ,,please help
  • FURRYe38's avatar
    I would reset the router and with a wired PC and web browswer connected to the back of the router, walk thru the setup wizard at 192.168.1.1. Be sure to write down all important information as you go thru the wizard for safe keeping.
    Review the online installation guide and user manual for addtional help.
    Netgear has set up a community forum specifically for Smart WiFi Router products:
    https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
    Thank you
  • michaelkenward's avatar
    michaelkenward
    What modem, if there is one, is in front of this router? The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
    The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
    I am surprised that Netgear still sells this device. According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN support only 10BASE-T or 100BASE-TX. That makes it slower than many newer internet services and most modern network hardware. This may not matter to you, but be warned that it will hobble you if you ever sign up for faster Internet. It also slows down whatever is going on in your local network. Newer devices support 1000BASE-TX.
