j_pic
Feb 09, 2016Guide
Can't turn on wireless
Today I updated the firmware on my Nighthawk X6. Since I've done so, it wont transmit a wireless signal. On the Netgear Genie, it says my wirelss is off, but when I click it, it's showing that everyt...
- Retired_MemberFeb 11, 2016
Just to be sure you're using the power supply that came with the router. 12VDC and 5 amp?
I have this same router and using same FW and everything is working.
Did you load a backup to the replacement router?
Also have you tried the reset with the replacement?
j_pic
Feb 09, 2016Guide
ok, i have reset and still dont have wireless, what should i do now?
Retired_Member
Feb 09, 2016Did you happen to push the radio off button on router
- j_picFeb 09, 2016Guide
No, that was the first thing I checked. All lights are on, all options inside of router are checked to transmit. I just spent 2 hours on the phone with support with no solution. They have decided to replace the router. Thanks for the help everyone.
