j_pic
Feb 09, 2016Guide
Can't turn on wireless
Today I updated the firmware on my Nighthawk X6. Since I've done so, it wont transmit a wireless signal. On the Netgear Genie, it says my wirelss is off, but when I click it, it's showing that everyt...
- Retired_MemberFeb 11, 2016
Just to be sure you're using the power supply that came with the router. 12VDC and 5 amp?
I have this same router and using same FW and everything is working.
Did you load a backup to the replacement router?
Also have you tried the reset with the replacement?
Retired_Member
Feb 11, 2016check that you have a SSID entered for each RADIO
Post a screen shot of each Wireless setup screen BASIC & Advanced
Clicking the yellow icon RADIO OFF should bring you to advanced wireless settings
Enable Wireless Router Radio should be checked
j_pic
Feb 11, 2016Guide
