j_pic
Feb 09, 2016Guide
Can't turn on wireless
Today I updated the firmware on my Nighthawk X6. Since I've done so, it wont transmit a wireless signal. On the Netgear Genie, it says my wirelss is off, but when I click it, it's showing that everyt...
- Retired_MemberFeb 11, 2016
Just to be sure you're using the power supply that came with the router. 12VDC and 5 amp?
I have this same router and using same FW and everything is working.
Did you load a backup to the replacement router?
Also have you tried the reset with the replacement?
j_pic
Feb 11, 2016Guide
Yes, Netgear phone support also had me do what he called a shock reset where i held down the reset button for two minutes unplugging and plugging back in every 15 seconds.
Retired_Member
Feb 11, 2016Just to be sure you're using the power supply that came with the router. 12VDC and 5 amp?
- j_picFeb 11, 2016Guide
So, after I updated my firmware, I unplugged my router and modem to move them and clean up my wire mess. Looks like when I hooked everything back up, I switched my router and modems power supplies. I didn't want to fess up to that and look silly, but I had to thank you for fixing my problem.
- Retired_MemberFeb 12, 2016
AMEN!! You're welcome,
I'm glad you got it working!
