Valis
Mar 03, 2020Tutor
Can't upload firmware file D7800-V1.0.1.56 over V1.0.1.28 - Firmware file is incorrect.
I've just downloaded the V1.0.1.56 zip file, extracted the image file and tried to install it, but get the firmware is incorrect error. This box is not yet connected to the Internet, so can't try tha...
- Mar 06, 2020
An update. When I put the D7800 on the net, I tried checking for a firmware update via the admin interface. It said there was no update available. When I went to write that up last night I wanted to get the error message correct, so did it again and it found 56! I asked it to fetch and install that this morning when it was quiet and all went fine, so I'm now running the latest firmware. I've no idea why these problems occurred or why it suddenly started working, but problem solved. Thanks for everyone's input.
Cheers.
antinode
Mar 03, 2020Guru
> This is a modem router. [...]
True.
> [...] The ISP is the one that updates firmware not end user.
True for a cable-TV-type modem(+router), but not for a DSL
modem(+router). Like a D7800, for example. (As reading the D7800 User
Manual would reveal.)
Back to the real world...
> Model: D7800|Nighthawk X4S - AC2600 WiFi VDSL/ADSL Modem Router
Is that accurate? Current firmware version?
> [...] extracted the image file [...]
Did you change its name? (I wouldn't.)
Netgear has issued some DSL devices with ISP-specific firmware
(identified by a suffix like "CH" or "SH" on what looks like a standard
firmware version, like "V1.0.3.6_1.0.63CH" or "V1.0.0.4SH"). Those
don't (easily) accept standard firmware.
It's also possible that the firmware in your D7800 is corrupt, and so
it can't tell "correct" firmware from "incorrect" firmware.
Possibly interesting:
https://community.netgear.com/t5/x/x/m-p/1543374
> [...] This box is not yet connected to the Internet, so can't try that
> method, [...]
I wouldn't expect that to help, but I'd certainly run the experiment
if nothing else (easier) worked.
If you get desperate, then you might try using the TFTP recovery
procedure to cram a fresh firmware image down its throat. See, for
example:
https://community.netgear.com/t5/x/x/m-p/1622096#M102004
Make sure that you have something appropriate to cram into your
gizmo.
Valis
Mar 03, 2020Tutor
Yes, V1.0.1.26 is the current version.
No, just extracted file as is.
No suffix. The file name is D7800-V1.0.1.56.img
Hmm, might try that.
example:
Ok, thanks.
