gapush's avatar
gapush
Tutor
Mar 29, 2018
Can't upload to usb storage from android
Hi, all. On my Android phone I'm using the genie app version 3.1.52. My x4s router has FW version 1.0.2.46. I have a WD drive connected to my router. I can use the ReadyShare feature of genie to down...
  • gapush's avatar
    Mar 29, 2018
    Duh. My own fault. I had enabled Admin Password Protection in router setup on the LAN shares. Disabled it and now it's working.
