random_543
Jun 13, 2021Follower
"Captive Portal AC1750
Please help Early today the breaker to the room that this wifi router serves tripped. So I flipped the breaker to restore power (this happens fairly often), after the power restarted I logged in to ...
antinode
Jun 13, 2021Guru
> [...] it now says my "captive portal is suspect" and I cannot use the
> internet.
"it"? What, exactly, says what, exactly, when you do what, exactly?
> Also netgear wants to charge me $129 [...]
Says who? Whom you contacted how?
> [...] to put into a technical ticket which I think is total BS
