sethf
Sep 24, 2016Aspirant
Cat peed on router...need help asap
How do you open the case of the Nighthawk R8500? I need to try and cover it with rice since my damn cat peed on it. Ive taken the 2 screws out of the back but cant seem to get it open. Thanks
- Jan 17, 2017
Retired_Member
Sep 25, 2016Cat urine isn't anything like water. The residue from it is nasty, If the router was on then most likely rice or any other trick to remove moisture is a waste of time. The pee more than likely caused a short circuit when it flowed over the motherboard.
I would place it in warm water and move it around to dissolve the pee, then rise with more water, then use a shop VAC to pull as much water as possible from it.
Use one of those storage bags that let you suck the air out with a vaccum filled with rice.
- William10aJan 16, 2017Master
Cat pee depending on how small the circuit board lands are it may be too late but have apart and want to try and save it. Remove the circuit from the router and use moonshine at lease with next to no water in it or 99.9 percent pure circuit boad cleaner and wash the board at lease two or three times. Now dry the circuit board in old oven at no higher then 250 degrees and no longer a 20 minute period. Good like
- sethfJan 17, 2017Aspirant
Ummm...no. Only do that if you want to make sure that the router doesnt work again. Also, who has moonshine laying around? Why does the oven have to be old?
From this past experience....if a cat pees on your router you just have to buy another one.
- William10aJan 17, 2017Master
Moonshine is easily enough to be had if you know the right people it will not eat most new plastic connectors and dries fast you have to disassemble the router and clean circuit board and off the cleaning solution with pure if possible now here is where comes in play after washing the circuit with pure or water. I would use old toaster oven or oven because of possibly of odors being left in it and I used a toaster oven in cleaning the tuners with knobs on them out of tv's 20 years ago lacquer thinner to remove the old and contact cleaner lps number 1 for the finger contacts and tuner grease number 1 then place tuner in oven for minutes at about 200 the grease melts and the tuner through out. Yes cat pee and circuit boards go back a long way the longer it stays on the board the more it eats since it acts like a acid end carries electric current very well. Remember pure water is poor conductor but the water in are home can conduct electric charges very well. That's why to the oven to dry the circuit board as the tuned radio circuits and micro controls all hate to be wet.
