sktn77a
Aug 10, 2021Virtuoso
Cat5, Cat5e or Cat6 cables supplied by Netgear with their routers
OK, not sure where to post this but seeing as it applies mostly to my R7000 gigabit routers, I thought I'd try here. Over the years (last 5-6 years or so) I've bought several Netgear routers which c...
sktn77a
Aug 11, 2021Virtuoso
Thanks. Were they marked as Cat5e?
Aug 11, 2021Guru - Experienced User
Some of them were. Not all.
I couldn't tell you which ones exactly because their mixed up with all my other cables so I'm not sure which ones came from which anymore.
But I do know I checked them out.
