EWzar01
Nov 12, 2022Tutor
CAT6e Cabling
I have a R7000P Nighthawk WiFi Router. Would like to upgrade the existing CAT5e cabling. Made and tested 3 new CAT6e cables using 568B standard. Removed CAT5e and replaced with CAT6e cable between ro...
Nov 12, 2022Guru - Experienced User
What CAT # is printed on the cable? There is no CAT6e cable type:
https://www.howtogeek.com/70494/what-kind-of-ethernet-cat-5e6a-cable-should-i-use/
CAT6 should work fine for the router.
What is the brand and model modem your using?
