EWzar01
Nov 12, 2022Tutor
CAT6e Cabling
I have a R7000P Nighthawk WiFi Router. Would like to upgrade the existing CAT5e cabling. Made and tested 3 new CAT6e cables using 568B standard. Removed CAT5e and replaced with CAT6e cable between ro...
Nov 13, 2022Guru - Experienced User
Why do you think you need to replace the cat 5e?
Cat 5e can support 2.5gig connections.
I have cat 5e in my home and run 2.5gig in all the rooms without issues.
In regards to your cabling issue, I've frequently seen home crimped ones that are crimpled wrong or poorly and not work. Sometimes they'll pass using a cable tester but only because it passes power and not data. So it'll pass the test but not work.
michaelkenward
That one occurred to me too. The constant "get a better cable" refrain we read around here is mostly background noise signifying nothing. It rarely, if ever, fixes problems.
Better to look at the underlying problem than to pour money into witchcraft.
