hxquero
Aug 23, 2021Aspirant
CAX80 blocking Samsung TV Plus
And the second I connect the TV to my T-Mobile hotspot - Samsung TV Plus works as it should!! NETGEAR needs to correct this issue ASAP.
hxquero
Sep 16, 2021Aspirant
Well, it's been a whole month and no solution. I'm at my wits end...I will NEVER purchase another NETGEAR product and I'm headed to Best Buy to purchase a Motorola!
Sep 16, 2021Guru - Experienced User
Please post about this over in the cable modem forum:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
I believe NG put forth a new FW update a bit ago regarding this. Something to try if you haven't already.
"@tamanaco wrote:
The issue with Samsung TV Plus was solved after I updated my CAX80 router firmware to version 2.1.2.6 today. WiFi calling appears to be working after this update as well" <Seems to be working for this user.
Helps to post in the right forum though.
Thank you.
- hxqueroSep 27, 2021Aspirant
I did update the firmware - still didn't work. Thanks.
- FURRYe38Sep 28, 2021Guru - Experienced User
Thank you.
