billg118
Jul 20, 2021Guide
CAX80 How do I block specific IPs?
I want to block google DNS (8.8.8.8) and for the life of me I cannot figure out how to do it on my CAX80. Does anyone know how?
michaelkenward
Jul 21, 2021Guru - Experienced User
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Control Access to the Internet.
You may have done that already. I can't tell from the limited information in your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here, but you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
billg118
Jul 21, 2021Guide
Yes I read the manual thoroughly. I read every section on any of kind access control and blocking I could find.
As far as I can tell the only blocking is keyword blocking.
Can this super expensive router/modem really not do a simple IP block?
- antinodeJul 21, 2021Guru
> I want to block google DNS (8.8.8.8) [...]
I don't know what that means. What, exactly, is happening which you
want to stop?> [...] for the life of me I cannot figure out how to do it on my CAX80.
For the life of me, I can't guess what you're trying to do.
> Did you respond to the wrong thread? [...]If it disappeared, then it was probably a scam-link post. Some
children post semi-random text in forums like this, and include a link
to some (typically malicious) web site. Sometimes, forum moderators
will remove such posts.- billg118Jul 21, 2021GuideI run my own recursive DNS via a PiHole with Unbound. This means I don't have to use a DNS service (normally your ISP auto-assigns theirs but there are lots including google, cloudflare, etc).
The problem is some Google smart home devices use hard coded DNS and bypass my recursive DNS server.
If I can block googles DNS servers (8.8.8.8 and 8.8.4.4) then those smart devices will be forced to use my DNS.
Blocking an IP at the router level should be simple and has been basic functionality on Netgear devices for decades. It's usually called IP blocking or static routes. I can't find either with the CAX80- antinodeJul 21, 2021Guru
And that's a "problem" because?Many Internet-of-Junk devices use a hard-coded DNS server for some
purposes. Generally for very good reasons.> If I can block googles DNS servers (8.8.8.8 and 8.8.4.4) then those
> smart devices will be forced to use my DNS.You think that you can bend them to your will through frustration?
I know nothing, but I'd expect them to stop working, because they
don't trust your personal DNS server. Which would be a wise approach
for IoJ (or general gizmo) security.> [...] It's usually called IP blocking or static routes. [...]
It is? By Netgear?
I can see how one might create a purposely defective static route to
achieve such a result, but I don't recall seeing a static-route
capability in any Netgear cable modem+router models. Plain router,
yes; DSL modem+router, yes. (Must be a feature.)
> Can this super expensive router/modem really not do a simple IP block?Looks that way to me, at least not using a static route. Possibly
interesting (including an authoritative response):
