cmong24
Feb 24, 2021Guide
CBR750 compatible with AC3000 Mesh WiFi Range Extender (RBS50Y)?
Hi I am curious if the AC3000 Mesh Wifi Range extender will work with my current CBR750 Orbi Tri-Band WiFi Router 4.2Gbps, Built-in Cable Modem Router. I am trying to boost my wifi signal to my sh...
Feb 25, 2021Guru - Experienced User
What is the shop made of for the exterior walls?
Many materials block wifi to an extent. Exteriors tend to be the worse because of insulation/venting/siding/etc. When people say "shops or garages" many times it has tin/metail siding which block wifi extremely well.
If its only 50ft away, sometimes a couple hours a burying an underground rated ethernet cable is a better investment for connection. Then you simply add an access point in the shop and its going to have a great connection.
cmong24
Feb 25, 2021Guide
It is made of metal (basic pole building) with metal roof and fiberglass insulation. That was my next plan to see about getting it's own dedicated line ran to the shop and set up an access point.
- plemansFeb 25, 2021Guru - Experienced User
if its a metal pole building, I'd burying the cable. You could do a point to point system but it'd be more expensive to go that route.
