Struktv
Dec 31, 2020Aspirant
CCTV not connecting via Wifi
I have just replaced my old router with the R7000 and cant get my CCTV to connect on the wifi. It will connect via cable but once the cable is disconnected I cant see the camera on the Connected...
antinode
Dec 31, 2020Guru
> I have just replaced my old router with the R7000 [...]
Did you configure the R7000 with the same wireless-network
credentials (SSID, passphrase) as your (unspecified) "my old router"?
(For the 2.4GHz band, I'll guess?)
> CCTV are cheapo Szsinocam 1MP [...]
Thanks for that detailed description. Even most cheap-Chinese junk
has a model number.
> Am I missing something? [...]
Configuring the cameras' wireless-network credentials to agree with
those of the R7000? (Or vice versa.)
Have you any other wireless devices which work or don't?
Struktv
Jan 01, 2021Aspirant
Yes same SSID and passphrase. Everything else in the house connected automatically.
Model of the Szsinocam is 1.0 MP IP Camera, SN IPC 5033SW AU
Just strange everything else works but these two cameras.
- michaelkenwardJan 01, 2021Guru - Experienced User
Did you try a reset of the cameras and building the connection from scratch?
- StruktvJan 01, 2021Aspirant
Yeah tried all that. Its funny but the new network is 192. and the old network was a 10. One of the cameras that I didnt setup on the new router can be detected by the router at a 10. but the one I physically connected has a new 192 IP but only works when connected and on wifi the router cant see it.
Something funny going on.
That can be a sign of two routers on the network. Often it is a modem/router in front of a router.
By default a router allocates itself 192.168.1.1 on setup. If it finds something "upwind" it will opt for 10.0.0.0.
What is your modem?
