IvyGirl
Jun 25, 2022Tutor
Cell phones can't connect to internet after Nighthawk setup
2 cell phones in our house cannot connect to the internet after setting up Nighthawk. One phone is a Google Pixel and the other is a Samsung Galaxy.
- Jun 25, 2022
What Nighthawk model are you referring too?
You gave us nothing to go off.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
Jun 25, 2022Guru - Experienced User
