Sakthivel
Mar 22, 2021Tutor
Certain Mobile apps not loading with Netgear Router/Spectrum internet
Hello, I am using this netgear router for a while https://www.netgear.com/home/wifi/modem-routers/c3700/ and switched to a new internet service provider - Spectrum Internet. With this new service...
- Aug 18, 2021My issue got resolved when the android OS got upgraded to Android 11.
Mar 22, 2021Guru - Experienced User
did you try changing the dns settings?
you can try googles at 8.8.8.8 or 8.8.4.4
or cloudfare at 1.1.1.1
- SakthivelMar 22, 2021Tutor
Thank you for responding.
Unfortunately changing the DNS settings to the suggested one didn't resolve the issue.
- plemansMar 23, 2021Guru - Experienced User
I'm not sure with Spectrum's firmware (they load it for the combo devices) if it supports enabling/disabling ipv6. have you tried/checked that?
- SakthivelMar 30, 2021Tutor
Thank you. I tried enabling/disabling IPV6 firewall protection - option which was available. But that didn't solve the issue.
