Sakthivel
Mar 22, 2021Tutor
Certain Mobile apps not loading with Netgear Router/Spectrum internet
Hello, I am using this netgear router for a while https://www.netgear.com/home/wifi/modem-routers/c3700/ and switched to a new internet service provider - Spectrum Internet. With this new service...
- Aug 18, 2021My issue got resolved when the android OS got upgraded to Android 11.
Mar 22, 2021Guru - Experienced User
did you try changing the dns settings?
you can try googles at 8.8.8.8 or 8.8.4.4
or cloudfare at 1.1.1.1
Sakthivel
Mar 22, 2021Tutor
Thank you for responding.
Unfortunately changing the DNS settings to the suggested one didn't resolve the issue.
- plemansMar 23, 2021Guru - Experienced User
I'm not sure with Spectrum's firmware (they load it for the combo devices) if it supports enabling/disabling ipv6. have you tried/checked that?
