celshaug
Jan 21, 2022Follower
Change default gateway R6230
Netgear Nighthawk Trying to add a second router in my shop, after several YouTube videos it looks easy but its killing me. I disabled the DHCP then I'm told to change my default gateway to the s...
Jan 21, 2022Guru - Experienced User
Is this the model router your trying to add as a 2nd router? What is the brand and model of the first router?
Only the WAN side would be needing to be changed. Or configure AP mode on the 2nd router for less configuration hassel.
Netgear has set up a community forum specifically for Smart WiFi Router products:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Thank you
