1124's avatar
1124
Follower
Mar 06, 2021
Change default passwordC6250
Can default password be changed?
How?
1 Reply
  • > Can default password be changed?
       The default password is the default password.  You can change the
    password from its default value to a value of your choice.
       _Which_ password?  Visit http://netgear.com/support , put in your
    model number, and look for Documentation.  Get the User Manual (at
    least).  Read.  Look for "Types of Logins".  For best results, keep
    reading.
