fuechy's avatar
fuechy
Follower
Jul 18, 2022
change device GHZ location
I have nighthawk X6 Model R8000 router. How can I change some of my devices like iPad, iPhone from 5 GHZ to 2.4 GHZ  and TV from 2.4 GHZ to 5 GHZ? I need help on each device to select each device which best wifi network band for its location.
fuechy@gmail.com  Thank you!
1 Reply
  • Go to the router settings
    Turn off Smart Connect if it's turned on
    Name each band differently (eg, MyWiFi-2G, MyWiFi-5G, etc)
