skhaire14
Jun 11, 2020Aspirant
Change DHCP Ending Address to 192.168.2.*
Hope some one can help me. In the LAN Setup of my router, I have chosen below option Use Router as DHCP Server Starting IP Address is 192.168.1.2 Ending IP Address is 192.168.1.254 ...
- Jun 12, 2020
Leaving alone the Netgear design decision for supporting /24 IP subnets only on the consumer (and some other devices): When I see a 255.0.0.0 subnet and then ....
skhaire14 wrote:I need Private IP and Public IP in two different subnets and they need to be able to communicate with each other
Here is my setup would look like:
Node 1 / Server A - Public IP - 192.168.1.101 Private IP - 192.168.2.101
Node 2 / Server B - Public IP - 192.168.1.102 Private IP - 192.168.2.102
So I need to be able to communicate using my router any address range between 192.168.1.2 to 192.168.2.254.
If you want two subnets, you need either two physically independent networks, or two VLANs, or the one network you have plus a VM internal network for private VM communication purely in software on the host - ll these making up two dedicated broadcast domains. On each of these two networks, you configure an IP subnet each, say 192.168.1.0/24 and 192.168.2.0/24. On each network, you have a DHCP, as (to keep it simple) DHCP can cover only one broadcast domain, and one IPv4 subnet.
The communication between the two IPv4 subnets must be done on a router with two interfaces, one in the .1.0 network, one in the .2.0 network.
With a 255.0.0.0 subnet, all addresses from 192.0.0.0 - 192.255.255.255 are in the same subnet - and can obliviously communicate as-is - and I assume the router will allow the communication. It does just not allow issuing DHCP addresses beyond of the 192.168.1.x address range. And I don't know if these consumer routers are able to handle NAT in this huge scope.
Said that: These consumer routers only support one (assumingly small) IP subnet and broadcast domain.
antinode
Jun 11, 2020Guru
> I need [...]
Why, exactly? What is the actual problem which you are trying to
solve?
> [...] to change DHCP Ending Address to 192.168.2.254. But upto
> 192.168.1 is greyed out. See attachement.
Change the LAN TCPIP/IP Setup : IP Address (and "Apply") first?
It'll still be grayed out, but the gray part should say "192.168.2".
You can't run the DHCP server in these things on a different subnet
from the router itself.
skhaire14
Jun 12, 2020Aspirant
Thanks for the reply.
I certainly do not need to connect more devices. My requirement is slightly different.
I am trying to set up a Two-Node Cluster using Oracle Virtual Box.
Hope this helps.
I am not sure if I am breaking community guidelines but I am able to achieve DHCP from my router using another Manufacturer.
- schumakuJun 12, 2020Guru - Experienced User
Said that: These consumer routers only support one (assumingly small) IP subnet and broadcast domain.- skhaire14Jun 12, 2020Aspirant
Thanks a lot schumaku.
1. With a 255.0.0.0 subnet, all addresses from 192.0.0.0 - 192.255.255.255 are in the same subnet - and can obliviously communicate as-is - and I assume the router will allow the communication.
Yes, you are right. I just realized that router will allow communication between these IPs and I am not creating two different subnets. However, the Cluster software/VM will not check and Cluster will identify that I have 2 sets of IPs 192.168.1* and 192.168.2.*, it will think that they are in 2 different subnets and that is fine with me as this is just for my testing and not real production.
2 .It does just not allow issuing DHCP addresses beyond of the 192.168.1.x address range.
And again, I am not sure why NETGEAR does not allow DHCP beyond 192.168.1.X range as I have consumer router from different manufacturer that allows me to get DHCP address beyong 192.168.1.X.
However, with subnet mask of 255.255.0.0, I was able to achieve my configuration as in the VM, I have configured STATIC IPs.
So here is my final configuration and that works fine.
Subnet MASK 255.255.0.0
DHCP Starting Address 192.168.1.2
DHCP Ending Address 192.168.1.254
Virtual Machines are hosted on 2 different laptops
Laptop A (IP - 192.168.1.2) Node 1 / Server A - Public IP - 192.168.1.101 Private IP - 192.168.2.101
Laptop B (IP - 192.168.1.5) Node 2 / Server B - Public IP - 192.168.1.102 Private IP - 192.168.2.102
And this just worked fine.
And thanks a lot for the help provided.
- antinodeJun 12, 2020Guru
> [...] Cluster will identify that I have 2 sets of IPs 192.168.1* and
> 192.168.2.*, it will think that they are in 2 different subnets [...]It will, _if_ the subnet masks on those interfaces are "/24".
> 192.168.1.X range [...]> [...] I doubt that you can use anything wider than a "/24" subnet on
> these routers. [...]Still true.
> configuration as in the VM, I have configured STATIC IPs."/16" is (slightly) less goofy than "/8", but why not "/24"?
Especially if the network interfaces on the computers use "/24"? If the
".2.*" addresses are both static, then why are you trying to get the
router to deal with them?
> Virtual Machines are hosted on 2 different laptopsWhat are the physical network interfaces? What are the virtual
network interfaces? How are they all configured?> And this just worked fine.
Perhaps for some values of "worked fine".
