Onecool94's avatar
Onecool94
Change Ip Extender Wifi Ex 3700
Hi,
I have in the same house two wifi extender Ex3700 and EX6250.
The problem is that they have the same ip 192.168.1.250.
So if I try to change some option i can access only a wifi extender.
There is a metod to change the ip of exstender?
Thanks a lot.
1 Reply
  • > The problem is that they have the same ip 192.168.1.250.
       That's the default IP address for one of these devices, but it should
    get a new/unique one (using DHCP) when it's connected to a router.
    > There is a metod to change the ip [address] of exstender?
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Read.  Look for "IP address".
    But you shouldn't need to do anything about it manually.  The manual for
    the EX6250 provides more details.
