Ryan256
Mar 26, 2025Aspirant
Change LAN side DNS - R7000P
I have set up a PiHole for ad blocking but I cannot find where to change the LAN side DNS for this router. With ever other router I've used that had this capability the LAN side DNS settings were on ...
Mar 26, 2025Guru - Experienced User
Can't change that on NG routers. DNS is proxied thru the router. The router uses what is auto detected or custom DNS for the WAN side. LAN side is always set to the router IP address for all LAN side devices.
