hman
May 15, 2017Aspirant
Change land code
I've found out that the land code in my router is set to DE and I'm living in Sweden. I've heard that this can cause interenence with outher wireless network in the neighborhood. My first questi...
- May 17, 2017
You have a point :smileywink:
hman
May 16, 2017Aspirant
That's correct. There is an option called Europe and that's what's selected as well.
I have a Mac and I've runned the integrated wifi analyze program.
The report from the analyze told me that there could be an interference between differnet routers if they have different land codes.
Then I found out that it was mine that uses DE as land code.
michaelkenward
May 16, 2017Guru - Experienced User
Apple gives believes that its users know nothing. So if you do know what you are doing it provides useless messages. That is its excuse for charging much more for its hardware
Wait until you see problems before you worry about this.
- hmanMay 17, 2017Aspirant
