Smiffy57
Sep 05, 2020Aspirant
Change Password
Hi, just joined up, I have a problem
I purchased a Nighthawk MR100 second hand. I have no way of contacting the seller.
I want to change the password and access upgrades but the unit is linked to another email address.
How do I sort this out please?
Smiffy57
At the top of the page here, go to the section labeled Downloads. Put in your model number and download the user manual.
In the user manual you are looking for a section titled Factory Reset Using the Reset Button.
Once reset, you will look in the same manual for a section titled Connect to the Mobile Router. The default user name and password are given.
- KitsapMaster
- Smiffy57Aspirant
Hi Kitsap,
Problem solved, thank you for your help
Smiffy
