captgadget
Nov 20, 2020Tutor
change the ip address of a connected device
I have the router DHCP set to 100 to 254 but my static ips fall in below 100. So I connected a new device with an assigned IP of .134 but I want that to be .25 in my static ips. How do I do that?
captgadget
Dec 03, 2020Tutor
Well I guess I must have bungled that question up. I what I was trying to say the newly connected device got an IP of xxx.xxx.1.134. I have a reserved section in my router where the IP address end in xxx.xxx.1.xx so I want to know, can I change the IP address of xxx.xxx.1.134 to an IP address of xxx.xxx.1.xx? That way it fits in my reserved IP address ending with 2 digits. NO STATIC ADDRESSES TO DEAL WITH! Sorry I confused you.
antinode
Dec 03, 2020Guru
> [...] the newly connected device got an IP of xxx.xxx.1.134. [...]
If that "xxx.xxx" is actually "192.168", then it's a private address,
and there's no good reason to hide any of it.
> [...] I have a reserved section in my router where the IP address end
> in xxx.xxx.1.xx [...]
"section"? I'm not sure what that means. Your term or Netgear's?
> [...] can I change the IP address of xxx.xxx.1.134 to an IP address of
> xxx.xxx.1.xx? [...]
If you configure a suitable Address Reservation on the router, then,
the next time these devices start up, the client device should get the
address which was reserved for it (in the DHCP server) on the router.
But creating a new reservation will not, by itself, change the
address of a running device. And the router might previously have
granted that newly reserved address to some other device, so it might
not be available now.
If you shut everyone down, and start everyone up again, then _all_
your address reservations should be effective.
