grimace's avatar
grimace
Change time zone on R7000 firmware 1.0.9.88
I can't figure out how I can know what time my router thinks it is.
I just set up my new router, R7000 AC1900. I want to set up an internet schedule that turns access off at night and on in the morning, so it's important that the day/time/timezone be accurate.
I see from previous posts that it used to be in Advanced > Security > Schedule but I don't see it there anymore.
Can someone help?
  • If the screens are the same as the R8000 (usually are) it is under ADVANCED ->ADMINITRATION->NTP SETTINGS.
