tommie
Dec 03, 2020Aspirant
Change wifi password for ex7000
How does one change the wifi password? I have changed the password for the wifi router and must now them for the extenders. This is an EX7000. Thank you
Dec 03, 2020Guru - Experienced User
You can log into it using the ip address of it and change it through its settings.
https://kb.netgear.com/26074/How-to-change-the-SSID-password-and-wireless-security-of-your-EX7000
tommie
Dec 04, 2020Aspirant
Thank you I will give that a try.
