GlennGundy
Apr 10, 2022Aspirant
Changed internet providers.
Changed internet providers, from Comcast to ATT. How do i connect my R7800 to the new internet address?
Apr 10, 2022Guru - Experienced User
Power OFF the ISP Modem and router for 1 minute then back on with the modem first then router.
- GlennGundyApr 10, 2022Aspirant
My router is connect in my office, my ISP modem (ATT/u-VERSE) is on the other side of my home. If I understand your direction, should I power them both off for 1 minute?
How can I tell which version of firmware I am using?
As noted, I have an ATT/U-verse modem. Model is BGW210-700
BTW, everything worked great with Comcast and not sure why the difficulty with ATT
Sure would appreciate a reply from e38 superuser, to my prior notes. Thank you!!
