GlennGundy
Apr 10, 2022Aspirant
Changed internet providers.
Changed internet providers, from Comcast to ATT. How do i connect my R7800 to the new internet address?
GlennGundy
My router is connect in my office, my ISP modem (ATT/u-VERSE) is on the other side of my home. If I understand your direction, should I power them both off for 1 minute?
How can I tell which version of firmware I am using?
As noted, I have an ATT/U-verse modem. Model is BGW210-700
GlennGundy
BTW, everything worked great with Comcast and not sure why the difficulty with ATT
- GlennGundyApr 10, 2022Aspirant
Sure would appreciate a reply from e38 superuser, to my prior notes. Thank you!!
- plemansApr 11, 2022Guru - Experienced User
att uses a modem/router combo device versus comcast is a modem only device.
Start with factory resetting your r7800. Then during install, you'll need to change your settings to fix the double nat from the 2 routers.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
