joeperez's avatar
joeperez
Changed network passwords, now PC won't connect!!!
I correctly followed the steps to change my router's network password from the default that came with the router. From within the Genie webpage I can confirm this (there are three different "networks...
  • joeperez's avatar
    joeperez
    Nov 09, 2016
    Yes, thank you. In Win10 I have the "Connect Automatically" box checked for the Nighthawk X10 (NETGEAR91) that displays in the list of available networks. So I get a connection practically as soon as I power up the PC.
