Kiddfam
Apr 20, 2022Initiate
Changed Router Wifi Password and now Iphones say "no internet connection" on 5G network
Our home webcam was hacked the other night and it was connected directly to our Netgear router so yesterday we changed the Wifi passwords for the 2G and 5G Networks via the Nighthawk app and checked ...
- Apr 20, 2022
did you try clearing the network settings on the iphone?
Also, are you using any parental controls/armor?
Are you using the "random mac/ip" feature on the device? try disabling it
Apr 20, 2022Guru - Experienced User
Kiddfam
Apr 21, 2022Initiate
So that was the solution. Had to go into all our iphones and reset the Network Settings. After we did that we went back into the Wifi networks, entered the new password and so far so good.
