Floorclowns's avatar
Floorclowns
Follower
Jan 23, 2022
Changed WiFi router how to get extender to connect to new router
How to get extender to connect to new router? Do I just unplug it to restart?
1 Reply
  • plemans's avatar
    I'd factory reset the extender (push and hold reset for 7-15 seconds while powered on).
    Then follow the install guide.
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
