Jeanb4720
Nov 29, 2021Guide
changement de routeur
bonjour, actuellement, j'ai un routeur Nighthawk ac1900 R7000 qui pose problème. J'ai acheté un nouveau routeur à savoir le AX12. Peut-on transferer les paramètres de l'un vers l'autre? ('jai to...
Nov 29, 2021Guru - Experienced User
en anglais s'il vous plaît
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
- Jeanb4720Nov 29, 2021GuideHello,
I currently have a Nighthawk ac1900 R7000 router which is causing problems. I have bought a new router, the AX12.
Can I transfer the settings from one to the other? ('I have my whole home network with assigned IP addresses)
Thank you in advance.- michaelkenwardNov 30, 2021Guru - Experienced User
Jeanb4720 wrote:
Can I transfer the settings from one to the other? ('I have my whole home network with assigned IP addresses)No. Different hardware.
All you can do it take a screenshot of the settings and manually renter them.
Or assign the IP addresses on the devices themselves.
Then again, what do you mean by "assigned IP addresses". Do you mean "reserved IP address" set on the router?
"Assigned IP addresses" are what you do on the devices connected to the router (see above). They should persist regardless of the router you are using.
