Jeanb4720
Nov 29, 2021Guide
changement de routeur
bonjour, actuellement, j'ai un routeur Nighthawk ac1900 R7000 qui pose problème. J'ai acheté un nouveau routeur à savoir le AX12. Peut-on transferer les paramètres de l'un vers l'autre? ('jai to...
Jeanb4720
Nov 29, 2021Guide
Hello,
I currently have a Nighthawk ac1900 R7000 router which is causing problems. I have bought a new router, the AX12.
Can I transfer the settings from one to the other? ('I have my whole home network with assigned IP addresses)
Thank you in advance.
michaelkenward
Nov 30, 2021Guru - Experienced User
No. Different hardware.
All you can do it take a screenshot of the settings and manually renter them.
Or assign the IP addresses on the devices themselves.
Then again, what do you mean by "assigned IP addresses". Do you mean "reserved IP address" set on the router?
"Assigned IP addresses" are what you do on the devices connected to the router (see above). They should persist regardless of the router you are using.
