RahulM's avatar
RahulM
Changing beacon Interval value and DTIM value
Hi,
I am using R8000P with latest firmware. I am trying to change Beacon interval value to 50 and DTIM to 3. But once I change and click on apply button. After restart value is back to normal 200 and 2. Why?
Can't I change those value?
  • michaelkenward's avatar
    michaelkenward
    RahulM wrote:
    Hi,
    What are you trying to achieve by making those changes?
    Start with the problem you want to fix rather than your idea of possible solutions. There may be other ways of reaching your destination.
    By the way, from the manuals it seems that those are not settings for routers. A few firewalls and ancient access points maybe, but router, no.
    • RahulM's avatar
      RahulM
      Why question answer is delt with another question.
      http://192.168.1.1/WiFi_HiddenPage.htm
      There is an option to change DTIM and beacon value which I can not change. I want to experiment it with something I do not want to disclose. But everytime I change it to something it goes back to default values why? If it can't be changed why give such an option?
      • microchip8's avatar
        microchip8
        Master
        These are hidden pages, used by devs and not intended for regular users. They're there to test things out, not permanently change values. There's a reason why they're hidden!
