nesasaurus
Sep 03, 2023Aspirant
Changing PPPoE to IPoE on Nighthawk X8
Hi I was on telstra velocity and had to migrate to their opticomm network. I previously had the Nighthawk AC5300 x8 router set up as PPPoE but this does not work with opticomm. I have done some r...
- Sep 04, 2023
Specify an Internet Connection Without a Login.
Does your Internet connection require a login? setting, leave the No radio button selected.
Select an Internet IP Address radio button: Get Dynamically from ISP. Your ISP uses DHCP to assign your IP address. Your ISP automatically assigns these addresses.
For IPv6, rom the Internet Connection Type menu, select DHCP.
FMI. Nighthawk X8 AC5000 Tri-Band WiFi Router Model R8300 User Manual
schumaku
Sep 04, 2023Guru - Experienced User
- nesasaurusSep 04, 2023Aspirant
Thanks for your response. No, we no longer require a login for opticomm (we did for velocity). I will try your suggestions and see how I go. Appreciate your time.
- nesasaurusSep 07, 2023Aspirant
Hi schumaku, I followed your instructions and it worked. Thanks for your help.
