murphygirl1541
Jan 10, 2020Tutor
changing router password
Please bear with me... I've never been here before and never tried to change the password to my router. The only way I could get to the login window was to enter the IP address. After I enter the us...
- Jan 11, 2020
When you sign into the router (how are you doing that? web browser? to 192.168.1.1?), you should get an opening screen with internet and wireless status. What do you see for "internet" status on the opening screen. Is the status "GOOD", or something else? Then under 'Wireless', do you see the SSID and password? Then go to your phone, 'forget' the old connection, and setup a new connection using the SSID and password seen.
duckware
Jan 11, 2020Prodigy
lower case admin/password?
murphygirl1541
Jan 11, 2020Tutor
Question: if I hit the reset button on the router, will it knock everyone off? Will we have to re-enter the password to get back on? Because that’s what I’m aiming for. My neighbor is piggy backing off my WiFi and it’s slowing me way down. I want him off. He doesn’t know the password so he won’t be able to get back on.
