csmith11
Feb 09, 2022Initiate
Changing the network name
I just replaced my router and it has a new network name. I connected the EX6100 to the new router following the WPS procedure. The EX6100 is still showing on my devices with the old network name. ...
- Feb 13, 2022
Worked like a charm! Thanks
Feb 09, 2022Guru - Experienced User
Try factory resetting the extender (push and hold reset for 7-15 seconds).
the install it using the installation assistant.
