dmoody
Jul 11, 2016Tutor
Channel Selection Limited on R7000
The channels available are extremely limited for 5 GHz (36, 40, 44, 48, 149, 153, 157, and 161). There are a slew of channels that common Wi-Fi analyzers recommend that seem to be unavailable on this...
- Jul 12, 2016
The FCC has been on vendors to lock down and only allow channels by country. Particularly (US) / North America. Best to use (non-DFS) channels 149-161 for 5ghz.
Wifi channels by country: https://en.wikipedia.org/wiki/List_of_WLAN_channels
How Dynamic Frequency Selection (DFS) works: http://www.wi-fi.org/knowledge-center/faq/how-does-dfs-work
Retired_Member
Jul 11, 2016Channel Plans are set by the FCC in the states as for the others countries I have no idea. One could asssume you're located in the States and 52 is Not available.
netwrks
Jul 12, 2016Master
- dmoodyJul 12, 2016Tutor
Well that's annoying. I get it and all, just annoying that I can't use the best channel because it *could* interfere w/ weather and Military stuff. So do the different firmware's for different regions behave differently or have a different set of channels available?
- Retired_MemberJul 12, 2016
dmoody wrote:Well that's annoying. I get it and all, just annoying that I can't use the best channel because it *could* interfere w/ weather and Military stuff. So do the different firmware's for different regions behave differently or have a different set of channels available?
This is exactly why the FCC mandates they be locked down by region so people like you can't cause a problem. If enough of your kind felt they had to break the rules it would cause a problem.
Your wifi analyzer is nothing but a cheap app that counts router beacons per channel and then makes a recommendation that most users thinks is gospel.
