Israel-ARP's avatar
Israel-ARP
Choose IEEE 802.11 mode
Hello everyone,
I am using the router for academic research,and I need it to use only 802.11b mode. How can I configure the router to do that?
  • JamesGL's avatar
    JamesGL
    Apr 03, 2017
    Hi Israel-ARP,
    Channel can be changed under the wireless settings. NETGEAR firmwares don't have options to select 802.11B.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Israel-ARP,
    The lowest mode that the router can be configured is 802.11G byt setting the mode to upto 54mbps.
    • Israel-ARP's avatar
      Israel-ARP
      Ok... But I need more than that.
      I want to configure its mode to 802.11b. And i just can't find a way
      to do that... is that possible at this router?
      • JamesGL's avatar
        JamesGL
        Hi Israel-ARP,
        This is not possible with the firmware of this router. As what I have mentioned, the lowest mode you can configure the router is the 802.11G.
