glbracer
Dec 20, 2021Follower
Circle 1st Gen Blocking Traffic
I seem to have a similar, if not the same issue, as this poster. Dishearteningly enough, it's been almost a year with no real response or solution. Once I got the Circle app set up, and turned on ...
Dec 20, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Circle product. Most of the people who watch that forum are more likely to have experience with Circle and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
https://support.meetcircle.com/hc/en-us
https://kb.netgear.com/000062852/How-do-I-upgrade-from-Circle-to-NETGEAR-Smart-Parental-Controls
https://www.netgear.com/home/services/circle-smart-parental-controls/
https://www.netgear.com/support/product/circle.aspx
