Noalv
Oct 07, 2021Follower
Circle cannot find netgear router
Hello, I installed Nighthawk on my Samsung galaxy s20 phone. I installed the router and turned on circle at parental control page I downloaded circle1 to my phone I tried to connect circle and the...
michaelkenward
Oct 07, 2021Guru - Experienced User
Have you tried this issue in the section given over to Circle?
Circle Smart Parental Controls - NETGEAR Communities
According to this list, the R6400 does not support Circle.
Which NETGEAR routers support Circle Smart Parental Controls? | Answer | NETGEAR Support
Has Netgear added it with new firmware since it wrote that article? Or is your router the R6400v2?
