cjs14
Jan 23, 2022Star
CM1000 and R7800 needs daily reboot
Lately on a daily basis our Optimum internet drops out , anywhere from noon to evening. only solution has been rebooting the modem but sometimes router as well. Modem is running fw 3.01.04 and r...
- Feb 03, 2022
cjs14 wrote:
So what do you recommend for a CM1000?
Might be worth trying that question here:
And check that it is compatible with your ISP.
cjs14
Feb 02, 2022Star
Thanks for the reply. Just checked cable conn, between 11.0 and 12.0 dBmV. Tech had said ISP look for 12dBmV or less at the modem and read online that -15 to 15 should be good. So what do you recommend for a CM1000?
Thanks
michaelkenward
Feb 03, 2022Guru - Experienced User
